forward traffic with DIA for Patricial URLs
banoosh
Hi Cisco Community,
I hope this message finds you well.
I’m currently working on a network configuration where I need to route traffic for specific URLs over Direct Internet Access (DIA). I would appreciate any advice or best practices on how to achieve this effectively.
personally, not yet tested but technically this should work:
1) define custom application by matching URL in the lists:
2) use application in the data policy, match app set nat vpn0 (DIA):
Note: You need SD-AVC to be enabled on vManage:
"Failed to create object: Failed to create custom app myapp in SD-AVC. SD-AVC response Failed to send SD-AVC create custom apps request.SD-AVC is not enabled on any vManage"
HTH,
HTH,
