How to configure ACL in vty cisco SDWAN on Vmanage
Hi all,
I want to configure ACL for vty of SDWAN OS Router.
I can create ACL in Localized Policy but can't find where to apply this ACL on Vmanage template.
Please help me to find this feature.
Thanks!
5 Replies 5
RohitRaj03827
Apply a Localized Data Policy in a Device Template:-
  1. In vManage NMS, select the Configuration ► Templates screen.
  2. If you are creating a new device template:
    1. In the Device tab, click Create Template.
    2. From the Create Template drop-down, select From Feature Template.
    3. From the Device Model drop-down, select one of the vEdge devices.
    4. In the Template Name field, enter a name for the device template. This field is mandatory and can contain only uppercase and lowercase letters, the digits 0 through 9, hyphens (–), and underscores (_). It cannot contain spaces or any other characters.
    5. In the Description field, enter a description for the device template. This field is mandatory, and it can contain any characters and spaces.
    6. Continue with Step 4.
  3. If you are editing an existing device template:
    1. In the Device tab, click the More Actions icon to the right of the desired template, and click the pencil icon.
    2. Click the Additional Templates tab. The screen scrolls to the Additional Templates section.
    3. From the Policy drop-down, select the name of a policy that you have configured.
  4. Click the Additional Templates tab located directly beneath the Description field. The screen scrolls to the Additional Templates section.
  5. From the Policy drop-down, select the name of the policy you configured in the above procedure.
  6. Click Create (for a new template) or Update (for an existing template).
This is how you can apply policy to vSmart by creating device template.
Let me know if you have still issue, i will write another post with one example with screenshot.
Kindly hit helpful button and mark as solve if this post has helped you.
Rohit Raj
Rohit Raj
My question is How to configure ACL in VTY, not how configure ACL. (Keyword is VTY).
Of course, we can apply ACL in interface for workarround, but not recommend.
I aslo opened TAC and TAC confirmed no option for this function.
Thanks!
I want to know if you got the solution for applying ACL on line VTY through any Template?
I'm also looking for the same.
You can check this link on the Device Access Policy section:
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/policies/ios-xe-16/policies-book-xe.pdf
with this policy, it will check the attempts to access from unwanted traffic on the control plane.
Hi all,
I had the same issue these days and the solution is:
- In Configuration/Policies you go right-top-corner and choose Access Control List;
- Choose Add Device Access Policy (permit_ssh);
      - Add ACL Seq:
                 - Match Conditions: SSH and Source Data Prefix List <my_jump_server_IP/32>
                  - Actions: Enable
             - Default Action: Drop Enabled
        - Save, Save
- Go back to Configuration/Policies/Localized Policy:
    - Add Policy;
    - Next, Next until Configure Access Control Lists step;
        - Add Device Access Policy (created previously: permit_ssh);
        - Next, Next; Check Implicit ACL Logging and I've added Log Frequency 2;
        -Save Policy (permit_ssh_Policy).
Now that the policy is created go on Router Template and in Additional Template tab, at Policy, choose the one you've just created (permit_ssh_Policy) and Update.
The configuration that is about to be pushed to router will be like this:
ip access-list extended test-acl-22
10 permit tcp 192.168.1.1 0.0.0.0 any eq 22
20 deny tcp any any eq 22
line vty 0 4
access-class test-acl-22 in vrf-also
line vty 5 80
policy
no app-visibility
no flow-visibility
implicit-acl-logging
log-frequency 2
That is how it worked for me.
Cheers,
Bogdan
