I am planning to connect my AWS VPC through SD-WAN via direct connect.
AWS has given the document saying the recommended configuration at our Data center side.
We will be ussing SD-WAN Cisco from the DC.
One of the configuratgions mentioned from AWS is to configure BFD fast failover in Custmer side device.
Would like to check if the BFD is not configured in the Customer side SD-WAN device & the BFD is only configured at the AWS side, will the BFD will work ?
Also if the BFD values are not matching will there be any issue with communication.
