how to configureHSRP on addition vlans on primary and secondary router in a cluster
jomo frank
Hello Expert,
I have two cisco router in HSRP configuration.
On each router I have a 4 port card.
The vlans configured on the card (both primary and secondary router) are Production Telephone,Security vlan.
I am to configure an use HSRP on the production vlan but Iunsure how to incorpoate Telephone and the  Security vlan in the configruation on the primary router is shown below:
For the production vlan I am using the 172.16.98.4 as the physical address and 172.16.98.1 as the virtual address.
How can I impleament same for the Telephone and Security vlan.
I trying to make the fail over seemless if the primary router should fail.
interface Vlan1
description Production Vlan
ip address 172.16.98.4 255.255.254.0
no ip redirects
standby 10 ip 172.16.98.1
standby 10 priority 120
standby 10 preempt
interface Vlan25
description AboveSecurity Vlan
ip address 10.189.10.1 255.255.255.0
interface Vlan91
description Digital Telephone Vlan
ip address 10.145.10.1 255.255.255.0
Regard
jomo frank
Hello Moderator,
Could you place this discussion under Routing or Networking It is currently under Other SD-WAN.
Simon Ko
Did you try following?
Primary router
int vlan25
  ip address 10.89.10.2 255.255.255.0
 standby 25 ip 10.89.10.1
 prio 110
int vlan 91
  ip address 10.145.10.2 255.255.255.0
 standby 30 ip 10.145.10.1
 prio 110
Secondary router
int vlan25
  ip address 10.89.10.3 255.255.255.0
int vlan 91
  ip address 10.145.10.3 255.255.255.0
