How to delete the Tenant in ACI from CLI
rajangahlout
Hi Team,
We have created the Tenant in ACI from APIC GUI, we also have created below items inside the Tenant:
1. contract
2. vrf
3. l3out (BGP)
4. bridge-domain
We want to delete the Tenant from APIC CLI, can you please help me with the steps and commands?
hemohemoh
hey @rajangahlout!
This is just based on my research. Hope some other experts can chime in!
  1. Login into your APIC CLI.
  2. Get the Tenant's DN (Distinguished Name) using the following command:
    apic1# moquery -c fvTenant -f 'fv.Tenant.name=="your-tenant-name"'
    Replace "your-tenant-name" with the name of your tenant. This command will return the Tenant's DN.
  3. You can then delete the Tenant using the following command:
    apic1# config
    apic1(config)# mo del 'uni/tn-your-tenant-name'
  4. To save the changes, use the following command:
    apic1(config)# commit
Make sure to back up your tenant. This operation is irreversible and once deleted, you cannot recover the data.
hemohemoh
hey @rajangahlout!
    apic1# config
