Cisco vManage API - Device status and control count?
arvinr
Hello All,
I'm new to APIs, and I was trying to utilize them to get the device reachability status and the vSmart control status/count, but I can't seem to find the right url to use. Do you know how to extract the correct data displayed in the picture below?
Target is to determine whether the connection via a particular transport is down for particular edges using the output.
Thank you
Try in device-counters option, we use resource URI /device/counters?deviceId=<system-ip> to get the number of OMP Peers, vSmart connections, and BFD sessions.
Device Counters for device =  10.10.1.17
│   OMP Peers Up │   OMP Peers Down │   vSmart connections │   BFD Sessions Up │   BFD Sessions Down │
│              2 │                0 │                    4 │                 2 │                   0 │
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
