How to detach offline vedge devices from vManage
R Manjunatha
Level 3
Level 3
I lost the connection from the vManage device, and I am unable to configure the default alternate route in the edge device. What is the option to detach the device from vManage to configure CLI mode?
I decommissioned the wan edge4 in the device list.
vEdge4# sh con
Possible completions:
configuration Display configuration history
control Display control information
vEdge4# show control connections
vEdge4# conf t
Entering configuration mode terminal
vEdge4(config)# vpn 0
vEdge4(config-vpn-0)# ip route 0.0.0.0/0 70.1.1.5
vEdge4(config-vpn-0)# commit
Aborted: 'system is-vmanaged': Commit from vManage is in progress. Configuration through the CLI is not allowed.
Looks, this is removed in latest releases and only TAC can help.
If it is production - open the case, if it is lab try to reboot the router.
HTH,
try by enforcing CLI-mode:
unhide viptela_internal
password should be : 5mok!ngk!ll$
system is-vmanaged false
https://www.cisco.com/c/dam/en/us/td/docs/routers/sdwan/Internal-Commands/Troubleshooting-Commands-for-Cisco-SDWAN.pdf
HTH,
Just I tried this command on the Vedge device and it's showing an error.
vEdge4(config)# unhide viptela_internal
Error: unknown hide group
HTH,
This is not a production it's just a lab. I can reconfigure the same to bring up once again Vedge device.
Thank you.
