How to learn default route from other site through omp ?
Ha Dao
Hi guys
My LAB is very simple, it have 2 vedge at 2 sites.
Site 1 have a default route and some static routes for service vpn 11.
From site 2 I can see all Site 1 's static and connected routes except the default route. So what I should do to get 0/0 route ?
Tks
svemulap@cisco.com
Not sure how you defined the default route.
If it is defined with a 'null 0' under service side as in
vE-20# show running-config vpn 1 ip route
vpn 1
ip route 0.0.0.0/0 null0
vE-20#
vE-20# show interface
IF IF IF TCP
AF ADMIN OPER TRACKER ENCAP SPEED MSS RX TX
VPN INTERFACE TYPE IP ADDRESS STATUS STATUS STATUS TYPE PORT TYPE MTU HWADDR MBPS DUPLEX ADJUST UPTIME PACKETS PACKETS
1 loopback1 ipv4 20.1.1.1/32 Up Up NA null service 1500 00:00:00:00:00:00 1000 full 1416 18:06:36:31 0 0
On the remote side - It will learn the default
vedge_w4# sh ip ro vpn 1 0.0.0.0/0
PROTOCOL NEXTHOP NEXTHOP NEXTHOP
VPN PREFIX PROTOCOL SUB TYPE IF NAME ADDR VPN TLOC IP COLOR ENCAP STATUS
1 0.0.0.0/0 omp - - - - 20.1.1.1 public-internet ipsec F,S
vedge_w4#
Hope it helps.
I tried 2 ways for default route in Site 1, but i can not be seen form Site 2
If I try to add ip route 0.0.0.0/0 null0 like you, it s ok, but how that default route working if we point it to null0 ?
#1
vpn 1
ip route 0.0.0.0/0 vpn 0
#2
vEdge1 learn default route via OSPF (running with other router at Site 1)
