How to put c-edge sdwan router in cli mode
I have a router and both isp link down and now router is unreasonable and wanted console but is it possible we can configure it via console as isp needs to change wan ip.
Enes Simnica
hello @ashishkumar01896 U can configure a cEdge through the console even if both ISP links are down....
  1. So just connect via console, log in, then run vshell to get into the full Ios-xe cli.
  2. From there, go into config terminal, update the WAN interface IPs/routes.....
Which means that once the correct IPs are applied, the ISP can bring the links back up and the SD-WAN tunnels will re-establish automatically....... Try it and let me know....
hope it helps and pEACE!
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
balaji.bandi
