Bookmark
Subscribe
410
How to view vManage Finite State Machine?
bmcgahan
This might be something obvious I'm missing, but is there a section of the vManage GUI that shows the FSM and previous/current tasks the vManage is working on?
For example, if I make a change to a device template and push the changes via vManage, but then browse to a different section of vManage while it's in the process of pushing the changes, how do I go back and check if it was successful?
TIA!
bmcgahan
Leaving this in case someone else has the same question, but I found it, and it was obvious...
The "Task List" is linked from the small bulleted list in the upper right-hand corner of the vManage GUI:
bmcgahan
