IP Sec Tunnel Between vEdge routers to Cisco ASA
Hi Team
 I Need help to Create IP Sec Tunnel Between vEdge routers to non SDWAN devices. Can you please help on this
G Muthu
ekhabaro
Here is an example.
ASA:
interface GigabitEthernet0/0
nameif Outside
security-level 0
ip address x.x.x.x 255.255.255.0
interface Tunnel0
nameif ipsec
ip address 10.10.10.1 255.255.255.252
tunnel source interface Outside
tunnel destination y.y.y.y
tunnel mode ipsec ipv4
tunnel protection ipsec profile tac_ipsec_profile
route Outside 0.0.0.0 0.0.0.0 x.x.x.gw 1
crypto ipsec ikev2 ipsec-proposal myset
protocol esp encryption aes-256
protocol esp integrity sha-1
crypto ipsec profile tac_ipsec_profile
set ikev2 ipsec-proposal myset
set pfs group2
set security-association lifetime seconds 86400
crypto ipsec security-association lifetime seconds 86400
crypto ipsec security-association replay window-size 512
crypto ipsec security-association pmtu-aging 10
crypto ca trustpool policy
auto-import
crypto isakmp identity address
crypto ikev2 policy 10
encryption aes-256
integrity sha
group 2
prf sha
crypto ikev2 policy 100
encryption aes-gcm-256 aes-gcm-192 aes-gcm
integrity null
group 14 5 2
prf sha512 sha384 sha256 sha
crypto ikev2 policy 200
encryption aes-256 aes-192 aes
integrity sha512 sha384 sha256 sha
group 14 5 2
crypto ikev2 enable Outside
group-policy IKE internal
group-policy IKE attributes
vpn-tunnel-protocol ikev2
pfs enable
ipsec-udp enable
dynamic-access-policy-record DfltAccessPolicy
tunnel-group y.y.y.y type ipsec-l2l
tunnel-group y.y.y.y general-attributes
default-group-policy IKE
tunnel-group y.y.y.y ipsec-attributes
peer-id-validate nocheck
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
vEdge:
vpn 0
interface ge0/0
ip address y.y.y.y/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service sshd
no allow-service netconf
no allow-service ntp
no allow-service ospf
no allow-service stun
allow-service https
no shutdown
interface ipsec1
ip address 10.10.10.2/30
tunnel-source y.y.y.y
tunnel-destination x.x.x.x
ike
version 2
rekey 86400
cipher-suite aes256-cbc-sha2
group 2
authentication-type
pre-shared-key
pre-shared-secret *****
local-id y.y.y.y
remote-id x.x.x.x
ipsec
rekey 86400
replay-window 512
cipher-suite aes256-cbc-sha1
perfect-forward-secrecy group-2
no shutdown
ip route 0.0.0.0/0 y.y.y.gw
Please make sure to use shared secret key longer than 16 characters for greater security
ekhabaro
Here is an example.
ASA:
nameif Outside
security-level 0
interface Tunnel0
nameif ipsec
set pfs group2
auto-import
encryption aes-256
integrity sha
group 2
prf sha
integrity null
group 14 5 2
group 14 5 2
pfs enable
ipsec-udp enable
vEdge:
vpn 0
interface ge0/0
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
allow-service https
no shutdown
interface ipsec1
ike
version 2
rekey 86400
group 2
authentication-type
pre-shared-key
local-id y.y.y.y
remote-id x.x.x.x
ipsec
rekey 86400
replay-window 512
no shutdown
