Bookmark
Subscribe
3083
iperf on viptela vEdge 2000
brian.holmes
Are there any limits on the iperf tool on the Viptela vEdge 2000?   I have 10G adaptors, so can I use the iperf tool to push 10G?  or should I try to find some other hardware and tool to push 10G?
Brian Holmes
Verizon
inderdeeps
Level 4
Level 4
Well if you are trying to use the iPerf from the vmanage( Speed test) it will not go beyond 250 Mbps. I tested via CLI on the vEdge and you can also test that, I wrote the full procedure for that, Go through the below link and you will try to check the bandwidth with that way.
Cisco Viptela SDWAN : Speed test via vManage Vs via CLI - Why differ ? (thenetworkdna.com)
Inderdeep Singh
***RATE MY RESPONSES IF YOU LIKE****
