Isr 1109 4plte2p VS Isr 4421
Hamada Ahmed
Something strange
What is the difference between isr 1109 4plte2p and isr 4421
Both can have two Wics LTE each Wic can has 2 Sim which means 4sim cards
So why list price of 1109 less than 4421?
5 Replies 5
Leo Laohoo
Because the size of the 1100 router is a lot smaller than then beefier 4000.
It all boils down to the size of the WAN.
But 1109 really can take 4 Sim cards?
And what is the Wan size for 1109 and 4421?
Because it's not really clear in Cisco datasheet.
I have a bunch of C1117-4PLTELA and only has two SIM slots.
I am not sure if a 4000-series router can support three or more SIM.
Cisco "claims" the 1000-series router can support up to 150 Mbps but I would take this is a pound of salt.
But 1109 4p lte2p
This mean it's 4 port ethernet and two slots LTE and one slot can take 2 Sim,
I think like this where we can confirm this information?
because they are not only LTE devices, they are routers can do much more than LTE functionality. ISR4K has better performance at least.
See datasheet and compare:
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
HTH,
