Issue with Device Template Configuration Update
M-ALASFAR
Hello Cisco Community,
I am encountering an issue when adding a device template to vManage. Although all the settings and configurations in the template are correct, I receive the following error:
Failed to update configuration - /ncs: devices/device {vedge-208b6178-9e5c-7e4e-dea5-7c53e04009fd}/config/vpn/vpn-instance{0}/router/ospf/area(0}/interface{ge0/0} : Interface referenced by OSPF; Configure an address or remove the reference.
Has anyone experienced a similar issue or could provide guidance on resolving this? Any insights would be greatly appreciated.
Thank you!
Can I see the policy you use? It seem it for control plane of OSPF.
MHM
I have created a vEdge configuration using the following steps in the Template:
1. Basic Configuration
System Settings
2. Transport & Management
VPN 0
OSPF: Enabled using vpn0-ospf template
Interfaces: ge0/0, ge1/1 configured in VBN Interface
VPN 512
3. Additional Settings
Banner added
In the Feature Template, I configured the following:
Interface ge0/0:
Static route: Device-specific
Tunnel: Enabled
Tunnel color: MPLS
Netconf: Enabled
OSPF: Enabled
SSH: Enabled
OSPF Configuration (vpn0-ospf):
Area: 1
Interface name: ge0/0
Generated Configuration on vEdge:
vpn 0
  no interface eth0
  interface ge0/0
    ip address 192.168.101.1/24
    tunnel-interface
      encapsulation ipsec
      allow-service all
      allow-service netconf
      allow-service sshd
    no shutdown
  ip route 0.0.0.0/0 192.168.101.254
vpn 512
  interface eth0
    ip dhcp-client
    no shutdown
commitI
In your OSPF configuration, you referenced g0/0 interface for area0, however that interface does not have IP so OSPF can pick it up.
Looks like ,you want to configure ospf but selected incorrect interface. Or you didn't configure interface before enabling OSPF.
HTH,
System Settings
VPN 0
VPN 512
Banner added
Interface ge0/0:
Tunnel: Enabled
Tunnel color: MPLS
Netconf: Enabled
OSPF: Enabled
SSH: Enabled
Area: 1
vpn 0
  no interface eth0
  interface ge0/0
    tunnel-interface
      encapsulation ipsec
      allow-service all
      allow-service sshd
    no shutdown
vpn 512
  interface eth0
    ip dhcp-client
    no shutdown
commit
