License question when redeploying an existing VMX in Azure
SDNDI
We need to redeploy an existing VMX in Azure because the current deployment is bound to a Basic SKU public IP and cannot be changed due to a resource lock. We plan to shut down the old VMX, generate a new enrollment token, deploy a new VMX from the Azure marketplace and enroll it using the existing license. Can you confirm that (1) this is the right sequence and (2) that the existing license will transfer to the new deployment without issue? Any tips or tricks I should consider?
0 Replies 0
