Multi hosted Viptela SDWAN solution
RichGarner6472
Can Viptela support access to the portals for performance and health metrics in a multi-hosted environment and segregate data between hosted entities?
husseino
Cisco Support Multi-tenancy, each tenant has its own login and dashboards. Also, in vManage you have RBAC capabilities that allow you create user with specific access. Also, if you are not using vManage in multi-tenant mode and using different VPNs to represent different segments or tenants, you can create user account with visibility on the VPN level.
https://blogs.cisco.com/networking/cisco-sd-wan-multitenancy-improved-efficiency-and-experience
https://www2-realm.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/vedge-20-x/systems-interfaces-book/sdwan-multitenancy.pdf
Spoiler
Please vote if you find this answer helpful
