my problem with GRE IPv6 Tunnel
Abood Khoeld
Hello Everyone , i have a problem when i try to make the GRE Tunnel between 2 routers
i want to make a GRE IPv6 tunnel between 2 routers " router1 and router3" And there will also be a router3 in the middle between the 2 router , the real IP Address of router1 is 4.4.4.1/24 and the real IP Address of router3 is 2001:1111:11aa:aa11::1/64 , and the IP Address the directly connected interface with router1 in router 2 is 4.4.4.2/24 , and the IP Address the directly connected interface with router3 in router 2 is 2001:1111:11aa:aa11::2/64.
i want to make a GRE Tunnel between router1 and router3 and i want to make the the IP Addresses of the tunnel interfaces in router1 and router3 IPv6
the real problem is that the command " tunnel destinaton <IP> " dosent support IPv6 , just IPv4 .
so can anyone help me ?
12 Replies 12
tunnel mode gre ipv6 <<- this need under the tunnel config
ipv6 unicast-routing <<- this need in global mode
Thanks for your reply, I appreciate it
I already did
But the real problem is that the command " tunnel destination <IP> " does not accept IPv6 addresses
do you run ipv6 unicast-routing ?
Abood Khoeld
yes , im sure about that
R1(config-if)#tunnel mode ipv6 <<- this first
R1(config-if)#tu
R1(config-if)#tunnel de
R1(config-if)#tunnel destination ?
Hostname or A.B.C.D ip address or host name
X:X:X:X::X IPv6 address <<- IPv6 appear under the tunnel
Abood Khoeld
so that is impossible to make the real destination IP Address from IPv6
thank you again for your replies
just give me 5 min
I found something interest I want to check
you are correc the router not accept the command even after I add tunnel mode ipv6
the issue is with ipv6 you use it not correct can you share the IPv6 you use in both router
Abood Khoeld
ahhh , im using cisco packet tracer so that the resson why i didnt found X:X:X::X after pressing " ? "
and in this command you cant use the prefix lenght
im using 2001:AD4:1:1::/64 in the router 3
and 199.132.1.1/24 in the router 1
and 199.132.1.2/24 & 2001:AD4:1:1::2/64 in the router 2 "the middle router between router1 and router3"
IPv6 Static Tunnel GRE | Tom G CCIE Blog (wordpress.com)
this IP is not correct, I have little experience in IPv6
I try using 2001:AD4:1:1::1 <<- and it success
you also can use IP in above lab if there is no ping between interface
Abood Khoeld
thank you very much for your answer , you helped me a lot
You are so so welcome friend
