NFVIS Deployement
navidn
I am wondering, is it possible o deploy Cisco NFVIS on third-party hardware ( Not Cisco UCS, ENCS, .. )?
Thanks in advance
@navidn : Are you asking the support of third party on NFVIS or NFVIS on 3rd Party compute hardware
The Answer is yes, you just need X86 Compute hardware to install NFVIS
5 Replies 5
navidn
Kindly, this is irrelevant.
regards
Do you know the minimum requirements to run NFVIS on these platforms? or any link which mentions that?
BR,
Navid
@navidn : And if you are saying other thing around that below are the virtual functions supported on NFVIS
