06-16-2021 04:29 AM
I am wondering, is it possible o deploy Cisco NFVIS on third-party hardware ( Not Cisco UCS, ENCS, .. )?
Thanks in advance
Solved! Go to Solution.
06-21-2021 06:30 AM
@navidn : Are you asking the support of third party on NFVIS or NFVIS on 3rd Party compute hardware
The Answer is yes, you just need X86 Compute hardware to install NFVIS
06-19-2021 11:54 AM
@navidn : Check if it helps
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
06-20-2021 10:42 PM
Kindly, this is irrelevant.
regards
06-21-2021 06:30 AM
06-26-2021 03:20 AM
Do you know the minimum requirements to run NFVIS on these platforms? or any link which mentions that?
BR,
Navid
06-21-2021 06:32 AM
@navidn : And if you are saying other thing around that below are the virtual functions supported on NFVIS
