No connectivity between vBond and vManage (20.1.1)
csco11633218
I am trying  to create a lab on ESXI 6.7 using vManage,vBond,vSmart with all VMs running the same version 20.1.1.
I am getting frustrated, maybe somebody here can point me to the right direction.
I have no connectivity between vManage and vBond, and the same problem  with vManage and vEdge.
connectivity between vBond and vEdge runs fine.
I tried to add a tunnel-interface at vpn 0 on vManage and leave it off on vBond with no success. Also tried with different version of vBond(19.3) but the same problem occur.
Does anybody know why the hell this is happening?
I will appreciate for any help
csco11633218
I solved the problem after reading carefully a lab guide at ciscolive. There is a note that says:
Note: By default, vManage OVA is configure with a single interface (eth0) Note II: Adding additional interface remaps eth0 to vNIC 2.
After remapping the vnics on esxi server connectivity runs fine.
csco11633218
