No Connectivity from vManage shell to my laptop's IP
VijayMunoli
I am currently exploring the SDWAN Sandbox to learn about SDWAN. As part of it I am trying to implement a webhook on my windows machine to which vManage will send Alarm Events.
Following are the steps:
  1. Created Cisco SDWAN Sandbox lab.
  2. Connected to the devnet VPN using the credentials provided from SDWAN Sandbox.
  3. Started the webhook:
    $ python webhook.py &
    [2] 1003
    (venv)
    @** /d/CiscoSDWAN/sdwan-webhooks (master)
    $ * Serving Flask app "webhook" (lazy loading)
Environment: production
WARNING: Do not use the development server in a production environment.
Use a production WSGI server instead.
    • Debug mode: on
    • Restarting with stat
    • Debugger is active!
    • Debugger PIN: 111-198-456
    • Running on all addresses.
      WARNING: This is a development server. Do not use it in a production deployment.
Running on http://192.168.1.103:5001/ (Press CTRL+C to quit
The above IP 192.168.1.103 is the IP Address shown in the Wireless LAN Adapter Wi-Fi section of 'ipconfig /all'
4. Now when trying the curl command from vManage shell i receive error that connection is not established. Ping and telnet to the above IP Address and port also not working from vManage shell.
Note that using Postman I am able to run vManage APIs successfully.
medcpucompany
No Connectivity from vManage shell to my laptop's IP . It looks like the management interface is inaccessible from vManage shell on my laptop, although I can access it just fine from the cloud.
For: @medcpucompany
@VijayMunoli @medcpucompany the devnet SD-WAN sandbox(s) by design and security posture does not have internet/outbound access.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
