No control connection between the controllers?
Lost & Found
Level 2
Level 2
I'm attempting to setup an SDWAN lab, but it seems that no attempts have been made to establish the control connection between the controllers even after installing the certificate? any suggestion?
Version: 20.9.2.1
Devices Controller:
Devices Certificate:
Configuration:
vManage vBond vSmart
system
host-name vManage
system-ip 99.99.99.10
site-id 10
admin-tech-on-failure
no vrrp-advt-with-phymac
organization-name layer3life
clock timezone Asia/Singapore
vbond vbond.local
vpn 0
dns 8.8.8.8 primary
host vbond.local ip 10.110.1.11
interface eth0
ip address 10.110.1.10/24
tunnel-interface
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service sshd
no allow-service netconf
no allow-service ntp
no allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 10.110.1.254
system
host-name vBond
system-ip 99.99.99.11
site-id 10
no route-consistency-check
vbond vbond.local local vbond-only
vpn 0
dns 8.8.8.8 primary
interface ge0/0
ip address 10.110.1.11/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service ospf
allow-service https
no shutdown
system
host-name vSmart01
system-ip 99.99.99.12
site-id 10
vbond vbond.local
vpn 0
dns 8.8.8.8 primary
interface eth0
ip address 10.110.1.12/24
ipv6 dhcp-client
no shutdown
Logs:
vBond# show orchestrator connections-history
vBond#
vManage# show control connections
vManage#
I tried restarting every controller and adjusting the interface-tunnel parameters, but the problem stayed.
can you assign IP directly to vbond in both vSmart and vManage instead of using FQDN.
vSmart does not have tunnel interface. You have missing configuration "sp-organization-name" on all controllers.
If above did not help, share show control local-properties of all of them.
HTH,
