Not able to upload files from vmanage to cEdge
BJD
I am not able to upload files from vmanage to cEdges
using command:
scp -P 830 /home/admin/ROOTCA.pem admin@10.1.2.2:/bootflash/vmanage-admin/admin@10.1.2.2
admin@10.1.2.2's password:
after applying password it gives error message " connection lost" however reachability is ok
on cEdge the it reflect below logs:
*Aug 9 15:41:50.924: %DMI-5-AUTH_PASSED: R0/0: dmiauthd: User 'admin' authenticated successfully from 199.1.1.1:53098 and was authorized for netconf over ssh. External groups: PRIV15
Hi @BJD
 Why are you trying to transfer file using scp with netconf port? Why dont you use standard port 22, which is supposed to be used with SCP protocol?
Hi @ Flavio Miranda
It`s because I want to transfer the file from vmanage
I got it, but, did you try to use only port 22 instead 830?
