OMP routes are NOT installed in routing table
dragonhunt9111
Hello all,
I'm new to SDWAN.
I have tried many times to advertise LAN route between vedge-left-hand side and vedge-right-hand side. but not success.
This is my simple topology.
- I check on vmanage: both Vedges are UP
- On Vsmart, I used command show omp peers and show omp routes, it seems to be OK, like below:
- On each vEDGE, I show omp tlocs received , it received prefix from remote site, but bfd-status is down (I dont know why it down?)
-Ping between two WAN IP of EDGE ok
Please someone help to check?
Thank  you very much
svemulap@cisco.com
Hi Dragonhunt9111,
>From your screenshots and information that you have provided, this is expected.
I see both the Edge devices are in the same site-ID.
Change one of the Edge Site to a different site-ID (eg. 2)
Everything should work as expected. (BFD UP, OMP Routes exchanged, etc.)
The concept of Site-ID is that, edges/remotes belong to the same site and they can reach reach other, via LAN side.
There is no reason, reach through the WAN / Transport side.
Hence, OMP doesn't advertise the LAN prefixes to each other.
HTH.
svemulap@cisco.com
Hi Dragonhunt9111,
HTH.
Very thank Svemulap. I change site-id to 2 on vEDGE2 and everything works as expected.
