Proof of Concept
Good evening,
I created my first SD-WAN Topology on which I have to create a Proof of Concept.
I already found out that the POC Tool in dCloud would be the best for that. However, I don't have any experience at all with SD-WAN, so I was wondering if it's even possible for me to create a Proof of Concept?
Best regards,
Max
osdesent
Hi Max!
The dCloud SD-WAN POC Tool 7.1.1 is very intuitive allowing you to create any SD-WAN custom topology including the controllers, cedges, vedges, IOS-XE (CSR1kv) and VyOS.
However if you don't have any SD-WAN fundatios it will be almost impossible to set up your POC becuase you really need to understand the technology to leverage the POC Tool.
Oscar Desentis
Oscar Desentis
Customer Success Specialist (SD-WAN)
