RE: On Premise SD-WAN Controller Deployment
faisal.memon
I am building on premise SDWAN setup, All the controllers (vManage,vBond,vSmart) are up and running on DC VLAN (Which is my Service Side VPN). The edge devices are not able to communicate with controllers as they are sitting in my DC network. What options do i have to get this working. Attached is topology of my setup.
Faisal
11 Replies 11
faisal.memon
Hi shhaldar,
Thank you. This document would be of great help when configuring policy. I am stuck with placement of controllers.
Are you using VPN 0 to connect them ? are all these able to build control connection with each other ?
Surjeet Singh
Yes I am using VPN 0 to connect them.
Have uploaded your serial file on vmanage, if yes what is the current stage of them invalid, staging or valid ? You can check this under certificate on vmanage.
Also paste output of show control local-properties and show control connection from edge devices and show orchestration valid-vedge.
Surjeet Singh
RohitRaj03827
Dear faisal.memon
Kindly read the below link, you will have a good understanding for CISCO Vipetal sdwan on-prem controllers deployment for cEdge/vEdge routers.
https://community.cisco.com/t5/sd-wan/sd-wan-controller-hosted-on-prem/m-p/3959525#M1447
Let me know if you still have any queries or doubts, will help you resolve the issue.
If you think that my post has answered your questions, kindly hit the helpful button and mark as a solve.
Rohit Raj
Rohit Raj
@confignetworks
  You can have a look at this Cisco Live presentation.
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2019/pdf/BRKRST-2559.pdf
  Let us know if it helps.
Best regards,
elesani
The first step for you would verify the connectivity in between one of the Edge routers and your Bond controllers. these are possible options on vBond controller:
  • does it have a default route?
  • can you confirm if there is an end to end connectivity in between vBond and a given Edge router?
  • do you have up to date list of authorised Edge devices?
Once you verify above, review below options on a given Edge device:
  • does it have a route back towards your on-prem control nodes (vBond, vSmart and vManage)?
  • are you using FQDN address or IPv4 address for your vBond controller configuration within your Edge router configuration? Make sure that FQDN is resolvable to vBond IPv4 address in case.
  • check control connection status from Edge router to confirm if control connection towards vBond is forming or not.
Last but not least, confirm if there is any firewall in between and if that firewall might be blocking control connections.
Let me know how did you go.
Hello. Did you find a solution?
I am stuck with this too. It worse I don’t see people helping much. Most of the post doesn’t have answers.
In my case I don’t have connectivity between VEDGES devices. I am doing On-Premise deployment with a vedge in-line, and firewall in the middle. I followed all the guides and nothing helpful. The best source for knowledge at this moment is through Cisco live.
cheers
Hi!
Did you solve the issue?
i’m struggling with exactly the same issue
Hello
From vM,
devices -device -device bring Up
SSH in v/cEDGE
show control local properties
show control connection-history
Kind Regards
Paul
lsolorzado
Hi Paul
Thanks for your response.
I’m working on the design so there's not deployed devices yet.
I need to plan before implement.
Regards!
