Replace nim card when cedge in controller mode
dijix1990
I have some problem, my NIM-ES2-8 was damaged on the isr4451, we changed the card to NIM-ES2-4 and now I can't change template, I want to replace switchport feature and when I aplly new template with feature switchport I get error
inconsistent value: Device refused one or more commands:
no interface GigabitEthernet0/1/4
% Invalid input detected at '^' marker."
no interface GigabitEthernet0/1/5
no interface GigabitEthernet0/1/6
no interface GigabitEthernet0/1/7
There aren't on the device now, and vmanage want to delete
How can I fix it? I tried to delete wan edge and add it again, but I stil get an error
I think it's because vmanage has configuration of device with no exist interfaces (I can see the running config through Configuration -> devices -> wan edge list ->)
I had a similar issue and as far as I remember we had to delete the router from vManage and reset/wipe the entire router's configuration.
Basically, just start over with that router's config and enrollment.
Even though at the IOS-XE level the interfaces are gone, you will still see them when checking in the SD-WAN configuration.
BR,
Octavian
dijix1990
There are non-existent interfaces on the device in the sdwan configuration
border-02#sh sdwan running-config | i 0/1/4
border-02(config)# no interface GigabitEthernet 0
Possible completions:
  0/1/0
  0/1/1
  0/1/2
  0/1/3
  0/1/5
  0/1/6
  0/1/7
border-02(config)# no interface GigabitEthernet 0/1/4
border-02(config)# no interface GigabitEthernet 0/1/5
Aborted: inconsistent value: Device refused one or more commands:
BR,
Octavian
Yeah, I want to do the same now. Delete router from vmanage and erase config for changing nim card, it's inconvenient though
