Same network for Service Side NAT Pool on different VRF
etalaveran
It is possible to configure the same network for Service Side NAT pool but in different VPN/VRF?
Ex:
VPN 1
Inside Local : 10.0.100.0/24
Inside Global : 192.168.100.0/24
VPN 2
Inside Local : 10.0.101.0/24
Thanks!
Vpn vrf ? What you meaning ?
But if i get this
Vrf 1 have 10.0.0.0
Vrf 2 have 10.0.0.0 no problem you can use it in case that each vrf go to different router not same one
In Cisco-Viptela SD-WAN, VPN is the same as VRF
What I mean is,  in the LAN side I have :
VPN 1 (= VRF 1)with 10.0.100.0/24 network . This network is translated (Service Side NAT)  to 192.168.100.0/24
VPN 2 (= VRF 2)with 10.0.101.0/24 network . This network is translated (Service Side NAT)  to 192.168.100.0/24
My question is : it's possible to use the same 192.168.100.0/24 for inside globlal(translated NAT address) in both VPN/VRF?
