SD-WAN 20.15.1 Creating a loopback interface using Configuration Group
svenus
Hi team,
 This may seem dumb but I could not find a straightforward way to do this without using the CLI add-on.
 Trying to create a loopback address within a particular service VPN, which is used as network management. But the feature adding interface in Service VPN only allows SVI or Ethernet. Can't find the place for adding loopback.
  Any insights?  Thanks.
You can use "Ethernet Interface" for "Loopback" !
Please remark this as a solution If this is helpful.
svenus
Thank you for providing the screen shots.  However, I am working on the config using the newer Configuration Group method.  Under the Service VPN (which is equivalent to the Service Profile VPN template), adding Ethernet Interface and name it as loopback will prompt me an error. See the screenshot.
Perhaps I'll open a TAC case to see what can I do.
End up answering myself if anyone sees the same issue.
The Interface Name must be with a capital "Loopback0" instead of "loopback".  That will work.
