SD-WAN and OVT
Working on a SD-WAN design for a customer using ISR$K routers.
New customer requirement between two of the sites is to support OVT for their Data Center support.
I think yes, but just want to double check that we will be able to support this.
balaji.bandi
You mean ISR Router support OTV, yes they do.
or you looking SDWAN- OTV mixing ?
BB
More that the SD-WAN routers will be able to support the MultiCast between OVT Edge devices and not the SD-WAN routers terminating the OVT traffic.
