SD-WAN AVC portal
mmc11
I enabled AVC on vManage and i see it is enabled and running thru cli, but I can't access AVC portal thru https://<vmanage_ip>:8443
It opens vmanage gui not AVC portal
Is the portal still available? i am running software version 20.9.3  in multitenancy mode
HI,
some month ago I asked to TAC how to access to dashboard. TAC engineer said that, it is removed from latest releases.
HTH,
6 Replies 6
Thank you @balaji.bandi,
I saw this document and already tried that with no luck, I guess it is a typo as I saw you should access port 8443 in cisco documentation.
The service is fore sure available but I am wondering if the portal is still available or discontinued?
The SD-AVC user guide at: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/avc/sd-avc/4-4-0/ug/sd-avc-4-4-0-ug/using.html
states that we access SD-AVC dashboard by: https://<service-ip>:8443
when I try, I get access to vManage dashboard, what is the problem?
https://<service-ip>:8443   ( please clarify what is device this service ip you using to connect - deovice hosted container ?)
Connecting to the Dashboard
Using a browser (Chrome recommended) with access to the device hosting the SD-AVC Network Service, open the SD-AVC Dashboard. The Dashboard is accessible using the service IP configured when setting up the SD-AVC Network Service, and port 8443, in the format:
check some verification before accesing the device as provided before - also for reference again command tool to verify :
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/218082-configure-sd-avc-on-sd-wan.html#anc8
below 3 part video give you more information if you are success installing AVC on device :
https://www.youtube.com/watch?v=JtdYIozlKZQ
BB
HI,
HTH,
Thanks @Kanan Huseynli
