SD-WAN Bulk API Issue when clustering.
4T2
So i've run across an issue w/ a vmanage cluster and the bulk API endpoint.
The statistics endpoint is only returning data for the cEdge devices connected to the same vmanage instance that i'm querying.
This results in only getting data for a portion of the devices on the cluster.
I've validated and repeated the results w/ the following api call for sure
/dataservice/data/device/statistics/devicesystemstatusstatistics?startDate=2024-07-31T14:40:34&endDate=2024-07-31T19:56:34&timeZone=GMT&count=10000
Has anyone run into this one before?
4T2
Oh, forgot to mention that the cluster is running 20.9.5.2
Mike1386
Thanks for your post. Could you please open a TAC case? According to the engineering team, this is not the expected behavior, so they can investigate further with the TAC case.
