Dual routers with Zscaler
dodgerfan78
Two SDWAN edge routers each with tunnels to Zscaler. All Internet goes over the tunnel to Zscaler. If router1 loses its Internet but its LAN side is still reachable, how do I get Internet traffic to failover to router2's tunnel to Zscaler?
6 Replies 6
Interesting, might try that. Thanks.
Zscaler add two routers or only one ?
MHM
No clue what you mean. 2 SDWAN routers, each has a single tunnel to Zscaler.
Ok' do you run vrrp?
MHM
you need either VRRP or routing in service-side.
With VRRP, tracking is available where if SIG fails, primary node (master) decrements priority and due to preemtion secondary node (backup) takes primary role.
With routing details are shared here:
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-zscaler-deploy-guide.html#Routing
HTH,
