sd-wan controller login issue
R Manjunatha
Level 3
Level 3
VBond and vEdge login issue, it's not accepting default password it says login incorrect
done
Mounting pseudo filesystems...
Setting up hotplug...
Mounting filesystems...
Setting hostname...
Configuring kernel parameters...
Configuring network interfaces...
Verifying current time against timestamp...
Setting up log files...
Starting services...
proc fs opened successfully
acpid: starting up with proc fs
parsing conf file /etc/acpi/events/powerbtn
acpid: 1 rule loaded
acpid: waiting for events: event logging is off
viptela 19.2.0
vedge login: admin
System Initializing. Please wait to login...
Login incorrect
vedge login: admin
Login incorrect
vedge login: admin
Login incorrect
vedge login: admin
Login incorrect
vedge login: admin
Login incorrect
Maximum number of tries exceeded (5)
viptela 19.2.0
vedge login:
Hi ,
I have not set any username and password for this device and its initial configuration, by default username and password should be admin and admin. its not accepting the username as a admin as shown in the configuration.
Hi @R Manjunatha . Does you solved the issue?.
It is VM and it is not password recover issue and it asks for user name and entering username it reboots right way.
