SD-WAN Firewall will not allow TCP only port filtering
aarato
It seems like the firewall functionality in vManage only allows TCP/UDP filtering. What if I only want to filter TCP ports? Too much to ask? :-) (see screenshot)
In the CLI it is represented as
object-group service XXXXX
  tcp-udp 5000
This must be a bug with the 20.1.1 code....any feedback is greatly appreciated.
aarato
It's a User Interface bug. I ended up using protocol numbers instead like 6 for TCP and that works.
aarato
