SD-WAN On premise deployment
maguatte.dieng
maguatte.dieng
the DMZ is a ISR Router not a Firewall . what type of NAT should be applied in this ISR router (WAN Router) ?
  • (1) (2) vSmart and vManage point to the vBond public IP address
-NATed public IP address
  • (3) vBond learns interface private and NATed public IP address of vSmart and vManage
-Private is pre-NAT, public is post-NAT
  • (4) vSmart and vManage use NATed public IP addresses for communication.
7 Replies 7
maguatte.dieng
why does ISP router change destination port? That should be question. It is not logical that destination port is changed (since it is bound to specific application port on remote machine) automatically by ISP router. Looks like your configuration has incorrect lines, check again.
HTH,
Below the Nat implemented
I had the problem with vsmart and ports. Nat was on firewall.
In your situation, looks like every port is translated to 12348.
Send output form show ip nat transl cmd.
Also, if you want vmange to use vbond publiic IP you need to use public color on the interface.
sent your config.
Dan Frey
I have a CAT8kv in front of the SDWAN controllers doing NAT so that vmanage/vsmart send to vbond the public IP and, vbond also learns the private and public ip of vsmart and vmanage.   This requires source and destination NAT using VASI interfaces so that packets can traverse NAT inside/outside domains.  This is a lab so 10.64.x.x are private IP and 10.100.x.x are "public" ip for DC1 and 10.200.x.x are "public" IP for DC2.
vrf definition VASI-OUTSIDE
 address-family ipv4
 exit-address-family
interface GigabitEthernet3
 description contrl-complex
 mtu 9216
 ip address 10.64.32.254 255.255.255.0
 ip nat inside
 speed 10000
 no negotiation auto
 ipv6 address 2001:10:64:32::254/64
interface vasileft1
 ip address 10.99.1.1 255.255.255.252
 ip nat outside
 no keepalive
interface vasiright1
 vrf forwarding VASI-OUTSIDE
 ip address 10.99.1.2 255.255.255.252
 no keepalive
ip route 10.100.1.0 255.255.255.0 vasileft1 10.99.1.2
ip route 10.200.1.0 255.255.255.0 vasileft1 10.99.1.2
ip route vrf VASI-OUTSIDE 0.0.0.0 0.0.0.0 vasiright1
ip nat inside source static 10.64.32.1 10.100.1.1 no-alias
ip nat inside source static 10.64.32.2 10.100.1.2 no-alias
ip nat inside source static 10.64.32.3 10.100.1.3 no-alias
ip nat inside source static 10.64.32.4 10.100.1.4 no-alias
ip nat inside source static 10.64.32.10 10.100.1.10 no-alias
ip nat inside source static 10.64.32.11 10.100.1.11 no-alias
ip nat inside source static 10.64.32.14 10.100.1.14 no-alias
ip nat inside source static 10.64.64.1 10.200.1.1 no-alias
ip nat inside source static 10.64.64.2 10.200.1.2 no-alias
ip nat inside source static 10.64.64.7 10.200.1.7 no-alias
vbond connections:
vbond_251_1_1# show orchestrator connections
        PEER                      PEER
         PEER     PEER     PEER             SITE        DOMAIN      PEER             PRIVATE  PEER             PUBLIC                                   ORGANIZATION
INSTANCE TYPE     PROTOCOL SYSTEM IP        ID          ID          PRIVATE IP       PORT     PUBLIC IP        PORT    REMOTE COLOR     STATE           NAME                    UPTIME
0        vedge    dtls     11.1.1.78        78          1           192.168.0.247    12346    192.168.0.247    12346   biz-internet     up              Cisco SA Demo - 17404   7:22:11:41
0        vedge    dtls     11.1.1.79        79          1           192.168.0.246    12406    192.168.0.246    12406   biz-internet     up              Cisco SA Demo - 17404   7:22:12:28
0        vsmart   dtls     11.2.251.4       251         1           10.64.32.4       12346    10.100.1.4       12346   default          up              Cisco SA Demo - 17404   7:22:11:03
0        vsmart   dtls     11.2.251.4       251         1           10.64.32.4       12446    10.100.1.4       12446   default          up              Cisco SA Demo - 17404   7:22:11:01
0        vsmart   dtls     11.2.251.5       251         1           10.64.64.7       12346    10.200.1.7       12346   default          up              Cisco SA Demo - 17404   7:22:10:46
0        vsmart   dtls     11.2.251.5       251         1           10.64.64.7       12446    10.200.1.7       12446   default          up              Cisco SA Demo - 17404   7:22:10:45
0        vsmart   dtls     11.2.251.4       251         1           2001:10:64:32::2 12346    2001:10:64:32::2 12346   default          up              Cisco SA Demo - 17404   7:22:11:04
0        vsmart   dtls     11.2.251.4       251         1           2001:10:64:32::2 12446    2001:10:64:32::2 12446   default          up              Cisco SA Demo - 17404   7:22:11:02
0        vmanage  dtls     11.2.251.3       251         0           10.64.32.3       12346    10.100.1.3       12346   default          up              Cisco SA Demo - 17404   7:22:09:26
0        vmanage  dtls     11.2.251.3       251         0           10.64.32.3       12446    10.100.1.3       12446   default          up              Cisco SA Demo - 17404   7:22:09:28
0        vmanage  dtls     11.2.251.3       251         0           10.64.32.3       12546    10.100.1.3       12546   default          up              Cisco SA Demo - 17404   7:22:09:29
0        vmanage  dtls     11.2.251.3       251         0           10.64.32.3       12646    10.100.1.3       12646   default          up              Cisco SA Demo - 17404   7:22:09:29
0        vmanage  dtls     11.2.251.3       251         0           10.64.32.3       12746    10.100.1.3       12746   default          up              Cisco SA Demo - 17404   7:22:09:16
0        vmanage  dtls     11.2.251.3       251         0           10.64.32.3       12846    10.100.1.3       12846   default          up              Cisco SA Demo - 17404   7:22:09:20
0        vmanage  dtls     11.2.251.3       251         0           10.64.32.3       12946    10.100.1.3       12946   default          up              Cisco SA Demo - 17404   7:22:09:28
0        vmanage  dtls     11.2.251.3       251         0           10.64.32.3       13046    10.100.1.3       13046   default          up              Cisco SA Demo - 17404   7:22:09:29
Helo Dan
Thanks for you answer .I think we have the same design, but I don't understand why I'm not receiving any connections on the vBond while I'm receiving connections on the vManage and vSmart.
Below the Nat that i applied on my ISR
vManage is attempting the following UDP connection to vbond.
11:53:47.383251 IP 172.16.11.12.12546 > 102.164.141.211.12346: UDP, length 165
11:53:47.428141 IP 172.16.11.12.12746 > 102.164.141.211.12346: UDP, length 165
11:53:47.479778 IP 172.16.11.12.13046 > 102.164.141.211.12346: UDP, length 165
11:53:47.680494 IP 172.16.11.12.12446 > 102.164.141.211.12346: UDP, length 165
When we do a TCP dump on the vbond. We see the src IP and dst IP of the packet natted correctly. However it seems the destination port number is changed from 12346 to 12348, not sure why that is happening.
11:52:25.640336 IP 102.164.141.212.12346 > 172.16.11.11.12348: UDP, length 165
11:52:25.711363 IP 102.164.141.212.12546 > 172.16.11.11.12348: UDP, length 165
11:52:25.813766 IP 102.164.141.212.12646 > 172.16.11.11.12348: UDP, length 165
11:52:25.813885 IP 102.164.141.212.12846 > 172.16.11.11.12348: UDP, length 165
11:52:25.845670 IP 102.164.141.212.12746 > 172.16.11.11.12348: UDP, length 165
11:52:25.916124 IP 102.164.141.212.13046 > 172.16.11.11.12348: UDP, length 165
11:52:26.008868 IP 102.164.141.212.12446 > 172.16.11.11.12348: UDP, length 165
What do you think are the probable causes preventing the connection between the vBond and the vManage?
EminaBrkanic
did you add allow-service all on vbond interface?
