SD-WAN RBAC
Hi All,
suppose the case, where SD-WAN fabric is implemented in a company. But one site is managed (should be managed) by its local site engineers. Is there RBAC based solution that allows specific user to do template change only to specific devices?
I see only high level option "permit template change or not", it is not device specific. So, that user may change not only local site router but in reality al templates-routers. Is there any other way that fixes requirement?
Thanks.
HTH,
Found feature Resource-group.
Short explanation video from Cisco SDWAN&Cloud channel
https://www.youtube.com/watch?v=48Ruza0wHYs
HTH,
HTH,
