SD-WAN Speed test supported devices || ISR
Amr_Younes
Hello All,
Is SD-WAN speed test supported on ISR 4331 and C1111?
To enable speed test (data stream from settings), is it must to add the vManage IP (either vpn 0 or 512) or do we have other options?
2 Accepted Solutions
osdesent
it is not supported on cEdges, it is only natively supported on vEdges as they run IPerf in the vshell.
Oscar Desentis
Customer Success Specialist (SD-WAN)
Amr_Younes
Hello All,
Just to keep this post updated with the latest, with the help of someone from Cisco found that speed test will be supported on 17.2.x for Cisco IOS XE SD-WAN devices.
This is the release notes: https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/xe-17-2/ios-xe-sd-wan-re-notes-17-2.html
5 Replies 5
osdesent
Oscar Desentis
Thanks Oscar
Amr_Younes
Hello All,
The below article may help you to test the speed via CLI
https://www.thenetworkdna.com/2021/02/cisco-viptela-sdwan-speed-test-via.html
Inderdeep Singh
Thanks for the information
