SD-WAN topology
Hi folks,
kindly check the below topology and suggest to me this topology is correct like OUR HO site wan edge and all controller  (VM, VB, VS) in the same subnet or same SIte ID? if remote branches user want to connect server which is on HO site so is it ok controllers and Ho site Wan edge in same site id because all ar in same subnet?
0 Replies 0
