sd-wan transport selection
R Manjunatha
Level 3
Level 3
"The SD-WAN Viptela spoke has two connections: one for DSL primary and the other for cellular secondary. However, it consistently routes traffic through the cellular connection only. I need to redirect this traffic to the primary DSL connection. What is the best option, and in which scenario is the cellular transport selected?"
which commands do I need to use to verify as mentioned scenario
5 Replies 5
you need to influence both ingress and egress traffic.
In order to influence ingress - inbound traffic you need to configure centralized control policy where OMP route preference is used, so traffic from other locations towards spoke uses tunnels via "DSL".
In order to influence egress - outbound traffic you need to configure centralized data policy where local-tloc is set as primary for the spoke for the traffic coming from spoke LAN going to other locations.
HTH,
R Manjunatha
Level 3
Level 3
I have not created any policy for primary and secondary transport VPN traffic. Regarding this BFD session, which transport will be primary? Both of my transport links are up, but all traffic is still routed to the secondary LET. Is the primary DSL link experiencing latency issues, causing the traffic to be routed to the secondary link?"
Let me know if there's anything else you'd like to add or adjust!
interface cellular0
hello interval 60000
hello-tolerance 301
interface DSL
Tunnel
hello-interval 5000
 hello-tolerance 31
bfd color biz-internet
 hello-interval 4000
multiplier 6
bfd color lte
 hello-interval 6000
multiplier 5
You showing in general configuration. you need to add policies to preferred color - what @Kanan Huseynli  was suggesting in the thread :
example read below configuration guide :
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/policies/vedge-20-x/policies-book/m-application-aware-routing.html
its all depends on the configuration you have applied, that we do not have any visibility.
BB
R Manjunatha
Level 3
Level 3
OK, do you want configuration ..show policy from vsmart
