Hello all,
My set up is;
SD-WAN 19.2.31
Running on EVE-NG
My problem is with certificate for vmanage. I have already tried OPENSSL and private CA XCA on UBUNTU and in both cases I have same error. I create CSR and then sign it and import RootCA, but when I try to install signed cert via GUI it says: failed to decrypt common name from certificate
Anyone had the similar problem? I think i have went through every procedure on net, but always get the same error.
Jan
