SD WAN
akhilv
Can anybody tell about the max bandwidth supported by Cisco3925 router for SDWAN deployment?
Is there any upgrade or any way to increase the same to 500Mbps?
shriramghatges
Hi Akhilv,
  3925 is not supported under sd-wan edge portfolio!
  Consider ISR4K series , specifically  4431 in ur case.
Cisco Viptela SDWAN Series
  1. Cisco Viptela SDWAN: A complete design for Large Enterprise
    https://www.thenetworkdna.com/2020/04/cisco-viptela-sdwan-complete-design-for.html
  2. Multicast and Cisco Viptela SDWAN Solution
    https://www.thenetworkdna.com/2020/03/multicast-and-cisco-viptela-sdwan.html
  3. Purpose of TLOC in Cisco Viptela SDWAN
    https://www.thenetworkdna.com/2020/03/purpose-of-tloc-in-cisco-viptela-sdwan.html
  4. Control Plane traffic security in Cisco Viptela SDWAN
    https://www.thenetworkdna.com/2020/03/control-plane-traffic-security-in-cisco.html
  5. DNS Security over Cisco SDWAN: Cisco SDWAN Integration with Cisco Umbrella
    https://www.thenetworkdna.com/2020/03/dns-security-over-cisco-sdwan-cisco.html
  6. Troubleshooting guide for Cisco SDWAN control connections
    https://www.thenetworkdna.com/2020/03/troubleshooting-guide-for-cisco-sdwan.html
  7. How to configure IPSEC static route in Cisco Viptela SDWAN
    https://www.thenetworkdna.com/2020/03/how-to-configure-ipsec-static-route-in.html
  8. Cisco Viptela SDWAN with Zero Trust Security Model
    https://www.thenetworkdna.com/2020/03/cisco-viptela-sdwan-with-zero-trust.html
  9. Zero touch Provisioning (ZTP) in Cisco Viptela SDWAN
    https://www.thenetworkdna.com/2020/03/zero-touch-provisioning-ztp-in-cisco.html
  10. Logic behind Application aware routing- Cisco SDWAN
    https://www.thenetworkdna.com/2020/03/logic-behind-application-aware-routing.html
  11. Cisco Viptela SDWAN Control Plane setup with Certificates!
    https://www.thenetworkdna.com/2020/03/cisco-viptela-sdwan-control-plane-setup.html
  12. Cisco SDWAN: vManage, vSmart, vBond setup from Scratch and the integrations with each other
    https://www.thenetworkdna.com/2020/03/cisco-sdwan-vmanage-vsmart-vbond-setup.html
  13. Cisco Viptela SDWAN Value Proposition
    https://www.thenetworkdna.com/2020/02/cisco-viptela-sdwan-value-proposition.html
  14. vBond in Cisco Viptela SDWAN
    https://www.thenetworkdna.com/2020/02/vbond-in-cisco-viptela-sdwan.html
  15. Cisco Viptela SDWAN: Troubleshooting commands for Control Plane, OMP and BFD
    https://www.thenetworkdna.com/2020/07/cisco-viptela-sdwan-troubleshooting.html
  16. Cisco Viptela SDWAN: Configure vEdge via CLI when attached to vManage Template
    https://www.thenetworkdna.com/2020/06/cisco-viptela-sdwan-configure-vedge-via.html
  17. How to upgrade the new image on Cisco Viptela SDWAN Controllers
    https://www.thenetworkdna.com/2020/06/how-to-upgrade-new-image-on-cisco.html
  18. Secure Segmentation in Cisco Viptela SDWAN
    https://www.thenetworkdna.com/2020/03/secure-segmentation-in-cisco-viptela.html
  19. Fabric Operation in Cisco Viptela SDWAN
    https://www.thenetworkdna.com/2020/03/fabric-operation-in-cisco-viptela-sdwan.html
  20. Cisco Viptela SDWAN Licenses and propositions
    https://www.thenetworkdna.com/2020/07/cisco-viptela-sdwan-licenses-and.html
