10-23-2023 11:32 PM
sdwan 20.6.3 vmanage 支持纳管哪些型号的edge ,应该在哪里查找这些信息呢?
以及其他版本的sdwan ,应该在哪里查找对应版本支持哪些设备纳管呢?
11-01-2023 02:16 AM - edited 11-01-2023 02:20 AM
您可以在思科SDWAN兼容性列表档案中查看支持的设备以及对应的软件镜像,请参考下面网址:
Cisco Catalyst SD-WAN Control Components Compatibility Matrix and Recommended Computing Resources
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/compatibility-and-server-recommendations/ch-comp-matrix-20-6.html
Johnson.L
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.You can also learn more about Cisco SD-WAN through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/networking-knowledge-base/cisco-dna-center-ask-the-experts-resources/ta-p/4394489] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
Log in to Community
