SDWAN Control connections issue
startx001
Hi all
I have a ISR1111-4PLTEEA version 17.3, using two WAN links, over ethernet and over LTE.
Both WAN links work but the problem is next.
When both WAN links are up, control connections are up only for ethernet
In the routing table, active is the route for ethernet, received via DHCP, which is ok.
Only and only when I unplug the cable, control connection become up for LTE.
How to bring up control connections for both links at the same time?
for ethernet, i use color public-internet, for LTE is used color lte and on vSmart i am using color public-internet.
I need it to use for Application-Aware Routing.
BR,
Vlad
Naseer Anjan
have you made any control connection settings in feature template like "Max control-connection 1" since it will be 2 by default.
also, vsmart end make color default and try.
gneslim
Is the interface being configured as a last-resort-circuit? If the interface is configured as last-resort, it will not come up as long as any other WAN interface is active.
