SDWAN Labs
Hello all,
What are the best labs to best used on Cisco dCloud for practice for SDWAN Fundamentals course?
Kind regards,
Ahmed Elhramy
@AhmedElHiramy0999 use the  Cisco Catalyst SD-WAN v20.9.1/17.9.1 - Single DC v1. It uses the following software and platforms:
  • Cisco Catalyst SD-WAN Manager, version 20.9.1
  • SD-WAN Controller and SD-WAN Validator, version 20.9.1
  • cEdge (C8000v), version 17.9.1
  • vEdge (vedge-cloud), version 20.9.1
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
11 Replies 11
@AhmedElHiramy0999
Paid LAB do you mean?
 Better is build your own lab in EVE from scratch
No. I mean the labs offered on Cisco dCloud website
@AhmedElHiramy0999
try devnet sandbox, has four sdwan sandbox you can use for free
What about the labs offered on Cisco dCloud website?
Any idea what are the ones that are mostly related to the course flow & topics?
Can you share a link to the course you are following? Regardless of the course I think that the "CML - Catalyst SD-WAN 20.15 Lab Custom Topologies" lab will be best suited to work through your lab scenarios.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Cisco SD-WAN Operation and Deployment
@AhmedElHiramy0999 if you are following the Implementing Cisco SD-WAN Security and Cloud Solutions (SDWSCS) there is a dedicated dcloud lab set up for this.
Hope this helps.
varunsharma007
You can explore Cisco dCloud for your requirements. If you prefer an on-premises solution, consider using EVE-NG.
Which labs do you recommend on Cisco dCloud that could be the best fit for my requirement?
As I need labs for practicing Cisco SD-WAN Operation and Deployment course
