How to T-shoot Application Slowness in SD-WAN environment
In my organization, we are facing application slowness issue on one of the site, and as i checked everything's looks good
when I checked on CLI like, all wan link is showing up and working and everything's looks good and no idea how to how we T-shoot from viptela Vmanage .
Can someone advice or help, how we T-shoot on VManage side.
Note: Vmanage verson they are using is 20.0 above.
to say smth from here is difficult.
Generally, you should understand your topology and check data/ control policies to see which path or paths used for forwarding (from local to remote and vice-versa).
At least, you can use vManage built-in tool NWPI  - network wide path insight to which how routers determine to forward the traffic between selected nodes or for protocol.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/network-wide-path-insight/network-wide-path-insight-user-guide/m-perform-network-wide-path-insight-tracing.html
HTH,
