SDWAN Multicast not working
Naseer Anjan
I am using 20.5.x and 17.5.1  SDWAN images in IOS XE SDWAN on ISR 4k. unicast is working fine but only multicast is problem..
Scenario 1 : when i use multicast RP (auto rp) on one site behind replicator only that site SDWAN router get RP registration but other site over the wan doesn't get RP update.
Another Scenario 2 , RP get updated but it is not able to reach source to destination while ping group address 239.1.2.3 . it is working just only once but second ping is not working.. i need to wait until S,G entry get flush out from mroute table . if again i ping group address and i am seeing just once response but next only dots (request timed out).
Scenario 3:  all same as per Scenario 2 except RP is not non SDWAN as RP enabled on HQ site router which is replicator too. result is same only.
Scenario 3: i put RP at all the sites and enabled MSDP across RPs. So, i am able to ping each other with no issues. But it is not acceptable solution when we run multicast across WAN for multiple branches since we cannot put dedicated RP router.
sd-wan_engineer
Did you manage to make it work?
Do you have any topology of your labs?
