02-07-2024 01:16 PM
Hello
My vedge routers all have control connections to vbond and in Up state (because of only one vsmart controller) over public internet transport. control connections from vedge routers to vbond state show connect (show control connections) and blank over MPLS transport. As a result all edge routers are in a partial control status state.
Why is the control connection from vedge to vbond over MPLS not Up? I have IP connectivity between vbond and the edge routers.
02-07-2024 02:20 PM
I think this depends on DNS resolve the vbond IP'
Can you check if DNS resolve public IP or private IP?
MHM
02-08-2024 04:47 AM
Thanks HM,
it’s an on premise POC, all controllers have private IPs configured
02-08-2024 10:35 PM
just I want to clear the topolgy here
Vedge have two transport interface one in internet and other in MPLS
Vedge can connect to Vbond via internet using it public IP
vBond send both vSmart (private and public IP) to Vedge
some of Vedge can connect to Vsmart via MPLS other not ?
if Yes can you check the non-work Vedge if it learn subnet of Vsmart (private IP) via MPLS?
MHM
02-07-2024 02:54 PM
when the device onboarding / coming online time only Control connection you see device and vbond, once the device onboard you only see connect with vsmart and vManage only.
its all depends on how you configured your transport configuration on the device, check the device template configuration.
02-08-2024 04:46 AM
I think when you have only one vsmart, the connections from wan edges becomes persistent to vbond, unless you change max connections to 1 on the vpn interface template. Also this is an on premise setup, all controllers have private Ip addresses on the inside of the network. The controllers all have transport on color public internet, but not color mpls. The wan edges have both transport internet and mpls. Internal routing allows the controllers to be able to reach the mpls transport on the wan edges
02-08-2024 12:28 AM
You just have control connection to vSmart over each interface, but to have this you must have control connection to vBond over each transport.
If for example, vBond is in internet and you didnt configure MPLS wan to somehow have connection till vBond, you control connections fails.
Depending on your design there are couple of ways:
1) advertise vBond and other controller public IPs as /32 route in mpls
2) route traffic to internet edge and do nat on somewhere (dc/hq)
3) disable control connection requirement by max-control connection 0 under mpls binded transport interface
In the option3, if you lose control over internet, then you devices will lose overlay control connections and you cant manage untill internet is re-established. However, dataplane still works based on omp graceful restart timer
02-08-2024 04:35 AM
Thanks Kanan,
I should also have mentioned this is an on premise POC. The controllers all seat on the inside network , with vbond having a private IP address only, but all controllers have access to the internet. The subnet that the controllers reside on is what I have as color public internet. The vedge routers have established dtls to the controllers over VPN 0 on this internet transport.
vbond currently does not have an interface on the MPLS transport, I will set this up based on your comments and see what happens. Will let the group know the outcome. Thank you
02-08-2024 04:39 AM
Kanan,
I wanted to add that vbond can reach the MPLS interfaces on the vedges via internal routing. The vbond does not have a transport at this time on the MPLS network. Is it still a requirement for vbond to have a transport in MPLS for the control sessions to come up in this scenario?
02-08-2024 01:51 PM
Controllers have only one interface for VPN0. Actually, controller VPN0 are not bound to any transport. But if you need to have control connections from each type of transport of routers towards controllers, you need somehow to make reachibility.
Couple of options exists. If you share details of color/ IP design, more better solutions can be found
02-08-2024 12:45 AM
Do vBond and vSmart have interface placed in vpn0 with color mpls? can you check the connectivity betwen edge and vbond/vsmart via mpls?
One transient DTLS control connection to the vBond orchestrator over each connected WAN transports only during the onboarding process.
One persistent DTLS control connection to vManage over a single WAN transport.
One persistent DTLS/TLS control connections to vSmart over each connected WAN transports;
02-08-2024 04:42 AM
vbond and vsmart only have transport in internet and not MPLS. It’s an on premise POC. All controllers are in inside subnet that has access to the internet. That inside subnet is color public internet transport. Internal routing allows the internet transport to reach the MPLS transport.
02-08-2024 06:49 AM - edited 02-08-2024 06:50 AM
So, you need to have connectivity between mpls and internet via your special router in your DC (where placed controllers)
for example
Branch-2#sh sdwan control connections table
LOCAL SHARED CFG
PEER SITE DOMAIN LOCAL PRIVATE PUBLIC SYSTEM LOCAL PRIVATE PRIVATE CONTROLLER REGION SYSTEM V ORG BEHIND
INSTANCE TYPE ID ID PRIVATE IP PORT PUBLIC IP PORT IP PROTOCOL COLOR REMOTE COLOR IP PORT STATE UPTIME GROUP ID ID SET IP NAME PROXY
0 vsmart 1 1 10.2.2.204 12386 10.1.1.30 12446 1.1.1.30 dtls mpls biz-internet 10.1.1.30 12446 up 0:00:12:13 0 N/A - fractal No
0 vbond 0 0 10.2.2.204 12386 10.1.1.10 12346 0.0.0.0 dtls mpls mpls 10.1.1.10 12346 up 0:00:12:14 0 N/A - fractal -
0 vmanage 1 0 10.2.2.204 12386 10.1.1.20 12446 1.1.1.20 dtls mpls default 10.1.1.20 12446 up 0:00:11:22 0 - - fractal No
Branch-2#ping 10.1.1.20
Sending 5, 100-byte ICMP Echos to 10.1.1.20, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/3 ms
Branch-2#trac
Branch-2#traceroute 10.1.1.10
Tracing the route to 10.1.1.10
VRF info: (vrf in name/id, vrf out name/id)
1 10.2.2.1 5 msec 3 msec 2 msec
2 10.1.1.10 25 msec 41 msec 41 msec
Branch-2#
so in my edge I have some routes in vpn 0
ip route 0.0.0.0/0 10.1.1.1 - public internet
10.2.2.0/24 10.2.2.1 - mpls for connecting between edges
10.1.1.0/24 10.2.2.1 - route to connect my controllers which have only public IP via mpls network
in my controllers
ip route 0.0.0.0/0 10.1.1.1 - def route to internet
ip route 10.2.2.0/24 10.1.1.1 - route to my mpls network via my router for routing between mpls and my internet network (my piblic ip's)
BTW if your mpls is L3vpn you need to your mpls provider do routing between mpls and you block of public ip's (I don't need it because I bought L2VPN for my edges)
02-13-2024 09:13 AM
Your default route covers the specific route below
My WAN edge routers mpls interfaces (10.10.x.x) have ip connectivity to the controllers interfaces (190.190.190.x) on biz-internet transport. The WAN edge routers also have an interface on biz-internet transport. So I do not see how this is a connectivity issue between the transports. There is a gateway that has routing between both transports that the WAN edge and Controllers all point to. Again I am using private IPs on all devices
WAN-EDGE-01# show control connections
PEER PEER CONTROLLER
PEER PEER PEER SITE DOMAIN PEER PRIV PEER PUB GROUP
TYPE PROT SYSTEM IP ID ID PRIVATE IP PORT PUBLIC IP PORT ORGANIZATION LOCAL COLOR PROXY STATE UPTIME ID
vsmart dtls 10.10.100.12 255 1 190.190.190.132 12446 190.190.190.132 12446 Lindos SD-WAN biz-internet No up 0:13:28:33 0
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls - connect 0
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 Lindos SD-WAN biz-internet - up 0:14:25:06 0
vmanage dtls 10.10.100.10 255 0 190.190.190.131 12446 190.190.190.131 12446 Lindos SD-WAN biz-internet No up 0:14:25:06 0
WAN-EDGE-01# show control connections-history
PEER PEER
PEER PEER PEER SITE DOMAIN PEER PRIVATE PEER PUBLIC LOCAL REMOTE REPEAT
TYPE PROTOCOL SYSTEM IP ID ID PRIVATE IP PORT PUBLIC IP PORT LOCAL COLOR STATE ERROR ERROR COUNT ORGANIZATION DOWNTIME
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls connect DCONFAIL NOERR 10 2024-02-13T16:10:00+0000
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls connect DCONFAIL NOERR 8 2024-02-13T16:07:15+0000
vsmart dtls 10.10.100.12 255 1 190.190.190.132 12446 190.190.190.132 12446 biz-internet connect DCONFAIL NOERR 3 2024-02-13T02:41:16+0000
vsmart dtls 10.10.100.12 255 1 190.190.190.132 12446 190.190.190.132 12446 biz-internet tear_down VS_TMO NOERR 1 2024-02-13T02:41:04+0000
vsmart dtls 10.10.100.12 255 1 190.190.190.132 12446 190.190.190.132 12446 biz-internet up RXTRDWN DISTLOC 0 2024-02-13T02:38:35+0000
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls tear_down DISTLOC NOERR 0 2024-02-13T02:26:39+0000
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls connect DCONFAIL NOERR 46 2024-02-13T02:26:35+0000
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls connect DCONFAIL NOERR 49 2024-02-13T02:22:05+0000
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls connect DCONFAIL NOERR 41 2024-02-13T02:15:49+0000
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls connect DCONFAIL NOERR 17 2024-02-13T02:10:33+0000
vbond dtls 0.0.0.0 0 0 190.190.190.130 12346 190.190.190.130 12346 mpls connect DCONFAIL NOERR 9 2024-02-13T02:08:17+0000
02-18-2024 09:21 AM
vbond have only one IP 190.190.190.130 it reach via Internet but not reach via MPLS
I mention in first time you need to add vbond IP that reach via MPLS
this make vpn 0 mpls transport interface can establish control connection to vbond via MPLS
MHM
