SDWAN NAT from Tunnel
Learning101
Need some help regarding the NAT translation in SD WAN environment.
I have created simple topology in my lab and it does not seem to work.
I want all the traffic from tunnel side on router cEdge-1 that has a src 10.0.0.0/8 and dst 192.168.1.0/24 to be their src IPv4 translated into IPv4 address 10.10.10.1. This address is on router cEdge-1 interface G1.
I have partially achieved that, but i'm having issues with returning traffic from service side on cEdge-1.
EXAMPLE
R2 ping:
Sending 1000, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Packet sent with a source address of 10.6.9.6
cEDGE-1 nat rules :
ip nat pool natpool15 10.10.10.1 10.10.10.6 prefix-length 29
ip nat outside source list global-list pool natpool15 vrf 696 match-in-vrf overload
Traffic Data policy cEdge-1:
from-vsmart data-policy _696_cEdge-1
 direction from-tunnel
 vpn-list 696
  sequence 1
   match
    source-ip      10.0.0.0/8
    destination-ip 192.168.1.0/24
   action accept
    count nat_src_861100929
    nat pool 15
  default-action accept
from-vsmart lists vpn-list 696
 vpn 696
IP NAT Translations cEdge-1:
Pro  Inside global         Inside local          Outside local         Outside global
icmp 192.168.1.1:176       192.168.1.1:176       10.10.10.1:176        10.6.9.6:176
I can see that the translation has been done, and I can also see the traffic is returning on cEdge-1 G1 interface.
Packet capture on cEdge-1 G1 interface
10.6.9.6 has been translated to 10.10.10.1 and sent to 192.168.1.1, and traffic is also returning from 192.168.1.1 to 10.10.10.1.
BUT traffic does not reach cEdge-2 router, I do not see any packets coming from cEdge-1 on cEdge-2 if i do packet capture.
Have in mind that if I remove NAT and put default route on R1 that points to cEdge-1 G1 interface, I can ping 192.168.1.1 from R2 , so it does not seem to be routing issue.
I presume there has to be something with the data traffic policy for direction from service ?
Thank you for your help
Best Regards
fniccola
ciao!
can you post also the configuration of transport and service interfaces?
I'll test this solution in my LAB
TKK
FabioN
cEdge-1
Transport :
interface GigabitEthernet0/0/0
 ip address XYZ
 no ip redirects
 load-interval 30
 negotiation auto
 arp timeout 1200
 service-policy output shape_GigabitEthernet0/0/0
Service :
interface GigabitEthernet0/0/1
 description LAN
 vrf forwarding 696
 ip address 10.10.10.1 255.255.255.0
 no ip redirects
 ip nbar protocol-discovery
 load-interval 30
 negotiation auto
 arp timeout 1200
cEdge-2
Transport
 description INET
 no ip address
 speed 1000
 no negotiation auto
 channel-group 20 mode active
Service
interface Port-channel10.696
 description LAN-696
 encapsulation dot1Q 696
 vrf forwarding 696
 ip address XYZ
fniccola
ciao!
I tested the configuration in my LAB, the behavior is perfectly the same as in your LAB.
- I can see the translation on edge1, but I cant ping from 10.6.9.6 to 192.168.1.1 (10.6.9.6 is correctly translated to 10.10.10.1)
Site1-cEdge01#show ip nat translations
icmp 192.168.1.1:18        192.168.1.1:18        10.10.10.1:18         10.6.9.6:18
- a possible solution is to use a NAT pool that start from 10.10.10.3 to what ever you want (tested work correctly)... In this case you will able to ping from 10.6.9.6 to 192.168.1.1 (10.6.9.6 is correctly translated to 10.10.10.3)
below my configuration:
on edge1
ip nat pool natpool1 10.10.10.3 10.10.10.254 prefix-length 24
ip nat outside source list global-list pool natpool1 vrf 1 match-in-vrf
on vsmart
policy
data-policy _VPN_1_NAT_test
  vpn-list VPN_1
   sequence 1
    match
     source-data-prefix-list      Source
     destination-data-prefix-list Dest
    action accept
     nat pool 1
lists
  vpn-list VPN_1
   vpn 1
   ip-prefix 192.168.1.1/32
   ip-prefix 10.0.0.0/8
  site-list 1001
   site-id 1001
apply-policy
site-list 1001
  data-policy _VPN_1_NAT_test from-tunnel
