SDWAN NAT's Via CLI
Tim_J_RC
Hi, I am working on migrating my legacy edge device to SDWAN.   Our edge devices have a bunch of different NAT's.   Static NAT outside source, Static NAT inside source,  PAT's, NAT Pools, and a few others that work well with CI, however seem impossible with SDWAN VMANAGE feature templates and data policies.
I would like to do these NAT's via CLI addon template, however I have had no success getting this to work.   I am currently using a C8000v image in EVE-NG to develop it.   Has anyone had success with getting NAT's to work via CLI?    I think some of the prblems I have is identifying my inside and outside interface.   My service side VPN201 is assigned an interface which I can set at 'ip nat inside' with no problems, however , what I think my outside interface would be is my Tunnel4 which in is VPN 0.    Any ideas?   I am really trying to keep this simple for my deployment teams.
There are two method to config NAT'
I will share doc. Help you in config.
If I forget please make me remember.
MHM
I'd appreciate any help.
